MF 1130 won't go into park...
scott
05-10-2004 19:27:39
My MF 1130 will no longer go into park. It was getting progressively tougher to get it in, now I cannot get it at all. Does not seem to be a linkage problem, goes into all other gears fine. No other problems. MP works fine. Any suggestions?
Charlie
05-11-2004 17:33:06
 Re: MF 1130 won't go into park... in reply to scott, 05-10-2004 19:27:39
The linkage on dash has three fiber type bushings. One bushing for high/low and two on main shaft of shifter under dash. The parking linkage is on left side of steering pestal and goes out of bottom side of steering pestal. Then linkage goes to the parking brake behind the left fuel tank. The parking brake paw has several teeth and mate with a gear on pinion. I might have some photos of the parking brake paw. Get under tractor with flash lite and look to see if the linkage is still on parking brake paw. If linkage is OK then you need to drain hyd fluid and fuel. Then take left fuel tank off and remove the cover for the parking brake paw.
