throttle handle on MF 165
Jacck
05-10-2004 18:05:49
Hello every one. I have order the books for my 1974 MF165 diesel but haven't receive them yet. The throttle handle always come back to idle position. So if I want full gaz I have to hold it, not easy when I have to handle the loader at the same time. Can anyone help me with this issue. I can't see where I have to make ajustment.
okie
05-10-2004 18:37:01
 Re: throttle handle on MF 165 in reply to Jacck, 05-10-2004 18:05:49
Weld just a little bump on each of the teeth of the steel piece that the fuel handle rides on. The teeth are likely just worn down some from years of use.
Marty C
05-10-2004 18:27:13
I have a MF165 w/ Perkins Diesel, I used a spring from the throttle linkage to the side panel and it works great, may not be the right way to fix it but it worked for my 165. There are 2 bolts at the bottom of the throttle linkage that is you tighten up that is suppoesed to tighten up the throllte arm.
The Hague
05-13-2004 19:36:46
 Re: Re: throttle handle on MF 165 in reply to Marty C, 05-10-2004 18:27:13
I had the same problem. the throttle shaft has two splines that are suppose to fit tight in a washer in fits through It can be fixed by taking the throttle mechanism apart where the large washer is pinched between the cork disks. On mine the pressed in splines on the throttle rod were wore and allowed the shaft to move to much. I tacked a welded on the splines and slowly filed them down until they re fit the slots in the washer. It now works like new.
Hope that helps.
