MF 135 how to bleed it??????
Philip o Sulliv
05-10-2004 14:18:44
Hi , i have no idea how to bleed it, its a 67 MF can anyone help me cause its kinda getting dark here ( lights dont work on it)
fatcat
05-11-2004 21:07:14
 Re: MF 135 how to bleed it?????? in reply to Philip o Sullivan, 05-10-2004 14:18:44
If you are talking about fuel I just went through that tonight. I have a desiel and i ran out of fuel. I cracked the number 1 Injector to let the air out an loosend the fittings on the injector pump turned the motor over till raw fuel came out of the injector pump tightened the connections then turned motor over till raw fuel came out of number 1 injectorfuel rail. Then tightened fuel rail bolt and it started. Hope this helps.
fatcat
05-11-2004 21:06:33
If yoy are talking about fuel I just went through that tonight. I have a desiel and i ran out of fuel. I cracked the number 1 Injector to let the air out an loosend the fittings on the injector pump turned the motor over till raw fuel came out of the injector pump tightened the connections then turned motor over till raw fuel came out of number 1 injectorfuel rail. Then tightened fuel rail bolt and it started. Hope this helps.
Ray,IN
05-11-2004 20:57:15
I think Big Dean published the procedure on his website(s).
