MF 165 and baler
mark
05-09-2004 19:23:13
I just purchased a MF 165/ gas. It is in good shape. My dad has a Hesston 5510 baler that I would like to use with it. The hesston book says the required HP is 55. My question is, can I run this baler if I make the bales smaller then fullsize? I think the baler will make approx 1000 lbs. I was hoping I could run it if I made the bales approx 800 lbs. Please email me at [email protected]
Thanks, Mark
Leroy
05-11-2004 04:26:22
 Re: MF 165 and baler in reply to mark, 05-09-2004 19:23:13
I believe they are rated at 52 PTO HP the same as the 3 cylinder 4000 Ford, earlier 65 were rated at less. Years ago had a hay conditioner book called for 35 HP, didn't even have a tractor that big, used a 28 HP most of time with a 18 HP under lighter hay. You are so close to what it calls for unless you havs some adverse condition don't wory about it or changing settings
Don-Wi
05-09-2004 20:49:48
What engine does yours have? the continental gas is only rated for 42 hp(what I have) and the perkins engines are rated for (I think) 48 hp. The 165 may be a little light to handle the baler on hilly ground, but on flat land it may work. I stress MAY work I assume the 165 has aux. hydraulics? I know some came with and most without them I added some on this winter to run a loader.
Donovan from Wisconsin
mark
05-10-2004 08:00:58
 Re: Re: MF 165 and baler in reply to Don-Wi, 05-09-2004 20:49:48
It is the continental gas engine. The terrain is very flat and yes it has 2 sets of dual action hydraulics. I hooked the baler to make sure everything worked and it worked like a champ. When I engaged the PTO everything sounded smooth,but the real test will be in the field.. I may go ahead and try it. Thanks for the reply
Mark
Don-Wi
05-10-2004 19:51:47
 Re: Re: Re: MF 165 and baler in reply to mark, 05-10-2004 08:00:58
Best Advise I can give you is take it slow and be careful, having that light of a tractor on a round baler. Ours is a continental gas and it seems like it has more hp than it's rated for. She sure does like to grunt when working hard.
