Location of hydraulic relief valve MF 202
James
05-09-2004 17:24:39
Where is the relief valve located at on the loader for an MF-202. Only have the loader hooked up, no backhoe...Thanks. How common is it for these valves to stick and cause a pump to crack????
Iowadave
05-11-2004 08:24:40
 Re: Location of hydraulic relief valve MF 202 in reply to James, 05-09-2004 17:24:39
If it's a model 200 loader, it's incorporated in the spool valve. Should be the large nut on the outboard side of the spool (If the spool's mounted to the driver's left). Not much you can do with it other than have it tested and cleaned, no service or repair recommended by the manual. Manual goes through indepth testing procedures using dealer testing equipment, would be interesting to hear if anyone knows of any homegrown test.
