MF35 Drum Brakes
Tony
05-08-2004 16:30:59
Hi,
I just tooke the drums off my MF35 whose brakes has not worked in the two months I have owned it. I was expecting to find a greasy mess haven read the archive comments about axle seals on these. But I did not. What would it look like if it was the axle seals causing a problem?
How thick should the linings on the shoes be? Mine are about 1/8". Is this enough? If so, what should I try?
Thanks,
Tony
David
05-10-2004 14:01:44
 Re: MF35 Drum Brakes in reply to Tony, 05-08-2004 16:30:59
Hello from South Wales UK,
If the drums and shoes are clean and you have a good pedal position but reduced braking efficiency, the following may be of help.
If you remove the shoes you will probably find wear at the end of the brake shafts where the shoes sit. The shaft has to turn further before the shoes start to lift, in severe cases it is sometimes necessary to adjust the brake rods. But it's not the answer.
As the shaft turns further, the leverage from the inner drop arm is reduced resulting in having to stand on the pedal to stop. The solution is easy. Slide the spring inside the backplate back and withdraw the shaft a little. Disconnect the rod. You can now get at both sides. Grind away some of the worn area and build it back up with weld, (hardfacing will last longer) If you suspect that the shoes are worn as well you can leave the weld a little proud. This will return the 'off' position of the shaft and should give you efficient brakes.
We have also found that linings do harden with age and are worth changing if you suspect this. It won't cost much to have them re-lined.
Hope this is of help.
David (South Wales)
Tony
05-09-2004 06:02:45
Thanks, I adjusted the brakes and rode around for 5 minutes with each one being pressed down. Seems to have done the trick.
Thanks again.
mowr
05-08-2004 21:44:58
If the shoes are free of oil, the brakes are adjusted up right and the linkages are working properly, check the shoes and drums for signs of glazing. If the shoes and drums are shiny, rough them up enough that they can grip each other again. Note: don't breathe the asbestos or get it on your skin.
Gordon
05-08-2004 19:19:25
Tony If the seals are leaking there will be grease from the rear end showing up on the backing plate,sounds like you have about half lining left on the shoes.try putting the drum and wheel back on then set the shoes up to the drums to where you can feel a little drag as the wheel turns, should notice a big change
