Unknown Massey Value
Willh
05-05-2004 08:55:56
Hey All. I've got a bit of a problem. Someone wants to trade me what he has described as a MH44 in fair shape (engine leaks oil badly from the head, plates welded to frame to make pushing ram,etc.) for my 1961 lincoln continental parts car. I believe the tractor to be a MH22 because I already have a 44 and it is much larger than the aforementioned tractor. He has also stated that it has a 4 cyl. Continental engine in it. I
know these came on the 22 but did they come in any other MH tractors? How much do you think this tractor is worth in the shape it's in? I apologize for not having serial no.s, but all of the appropriate places for nos. were either worn off or missing. Any help would be greatly appreciated.
ET
05-05-2004 12:02:25
 Re: Unknown Massey Value in reply to Willh, 05-05-2004 08:55:56
The overhead valve engines used in 44's and 33's and the triples were all made by coninental.
Dave_Id
05-05-2004 09:36:11
Just about all the Mh's were 4 cylinder except for the 101, 101 & 102 Senior, and 44-6. The ser.# is stamped on the top or the transmission case. You may need to do some scraping .. Post the number and someone will tell you the model and year..
willh
05-05-2004 09:53:08
 Re: Re: Unknown Massey Value in reply to Dave_Id, 05-05-2004 09:36:11
Thanks Dave, I'll look on the transmission. I knew a lot of them came with a four cylinder, I was wondering how many came with the Continental four cylinder. I have a 44 standard and it doesn't have the Continental engine. Thanks again for the heads up on the ser. no. location.
Scott
05-05-2004 20:32:38
 Re: Re: Re: Unknown Massey Value in reply to willh, 05-05-2004 09:53:08
Their were many early Massey Harris that had a flat head 4 cylinder engine. The 22 has a 140 cubic inch and the mustang used the same engine as well. Check out the link below for more info on Massey Harris. They have a lot of info on most of the different model Masseys that might help with identifying the tractor.
Bob
05-05-2004 18:52:41
MH 44s had Continental H260 overhead valve engines. A 22 would have a flat head engine and stamped steel frame instead of the cast iron bath tub.
James Tx
05-05-2004 14:21:57
I think on the 44s they had a pad on the block with the engine size. I believe its on the carb side of block below the deck surface at the rear. The MH-20 used a 120 and the MH-22 used a 140 engine.
