oil blowing out breather tube on massey 135 3cyl.
J. B.
05-02-2004 05:25:45
I have a massey 135 3cyl. perkins diesel. It sat for aprox. 2yrs. Now after starting up it smokes pretty bad for 10 to 20 min. Then it will blow oil out the breather tube in about 5min. after it's started. It starts real easy. this winter when cold fired right up. Any ideas??
jake
05-02-2004 05:41:50
 Re: oil blowing out breather tube on massey 135 3c in reply to J. B., 05-02-2004 05:25:45
i'd bet you have a ring or two stuck at the piston grooves due to the pretty long time it set
chuckcat4
05-04-2004 00:40:01
 Re: Re: oil blowing out breather tube on massey 13 in reply to jake, 05-02-2004 05:41:50
if it starts good I would look at fuel pump to see that its not dumping fuel in the oil
if oil has fuel in it drain it and change it don't run with thined oil it will wash out your bearings and cyl walls and you will scrap the motor that will be costly$$$$$$
