Antifreeze +0il MF65
Wilho
04-30-2004 14:58:54
Ipurchased this tractor a few months ago. Have been working on it ever since. The antifreeze in oil has been the biggest problem. Which I think I have solved. Took off head;looked good took oil pan off. Icould see water leaking along side of sleeves. Poped out a sleeve and it just has rubber o rings to seal the sleeve. Could not order just the O rings So I went to a industrial supply and ordered that size o ring. Does anyone know if these o rings are special in anyway that might create a problem. Thanks
Wilhu
05-01-2004 04:55:29
 Re: Antifreeze +0il MF65 in reply to Wilho, 04-30-2004 14:58:54
Yes this is a G176 cont, gas. Thanks for the reply.
marlowe
04-30-2004 17:50:57
is this a gas engine? because diesels have dry sleeves. as to the O rings i just lube them up with a little grease and slide the sleeve in
