130masseyferguson
tim
04-29-2004 18:05:24
Im looking for brakes for a 130 masseyferguson I noticed through this forum a couple of people saying they had these or knew of a place to purchase them. Any help would be great. Thanks
Phil squires
06-01-2004 12:12:27
 Re: 130masseyferguson in reply to tim, 04-29-2004 18:05:24
I can supply new brake pads, not expensive
[email protected]
Phil
Jr.
05-04-2004 05:43:10
Tim,I was able to get a set ordered through Wilson tractor supply in Shelby N.C....the bad part is they cost me $280.I couldn't beleive it.He also got me a parts book & manual.hope you have better luck than I did
phil
05-01-2004 05:54:39
If i remember the 130 has a two sided brake pad that is curved and tapered to fit into a pully[brake drum] mounted on the drive axle same as a MF25. I had a local heavy equipment brake re-build shop[ off road trucks/winches,etc] rivit on a material of the correct thickness, and then with a dremel/mini grinder i tapered the sides down to what was needed for fitting the axle brake "drum". A cardboard template of the "groove" can be used to give a reverse image of the shape you need; if the orginal material is totally gone, off the actual shoe.
Be sure to wear a breathing mask when fitting, and ask for an "oil" resistance material to be installed. With a couple of trial fittings on the first one the other three were/are eaiser and operate as good as orginal.
Good luck
