pony equiptment hookup
John
04-29-2004 16:40:33
Go to the equiptment photos clic on massey catagory. i posted 4or 5 photos there
youngster
05-01-2004 05:35:18
 Re: pony equiptment hookup in reply to John, 04-29-2004 16:40:33
do you widen the tires to plow or do you leave them in. mine are in but it seems to only take a little bite of ground like that.
John
05-02-2004 10:59:25
 Re: Re: pony equiptment hookup in reply to youngster, 05-01-2004 05:35:18
If your tires are getting only partial bite then you have to much air in them. I only run about 10 to 15 lbs. in the loaded tires. John
John
05-02-2004 11:05:59
 Re: Re: Re: pony equiptment hookup in reply to John, 05-02-2004 10:59:25
I leave my tires in if you widen them the furrow is to wide for the draw bar adjustment The plow should measure 14 to 16 in. from inside the back tire. John
gardener
04-30-2004 09:23:59
Thanks for the instructive photos!
FYI :
Currently there is a set of bellymount cultivators on e-bay.Could be the final bidding day. I would buy them , but they say they wont ship them, especially to canada. Theyre in NC.
51 Pony
05-01-2004 03:45:20
 Re: Re: pony equiptment hookup in reply to gardener, 04-30-2004 09:23:59
Those Ebay cultivators are only half complete. They're just the toolbars and brackets. No spring tooth, or anything else with them.
gardener
05-01-2004 07:41:24
 Re: Re: Re: pony equiptment hookup in reply to 51 Pony, 05-01-2004 03:45:20
Yup, i could see there was something missing, but figured i could substitute/make up the missing parts. A square bar shouldnt be hard. The spring teeth would be more challenge. I thought about using the shanks off an old wrecked spring tooth rear cultivator.
Fortunately, in the meantime i've found a local Pony example which i can copy.
Does anyone out there know if the Farmal Cub has the same setup/components?
John
04-29-2004 19:08:05
my plow is a 52 the field cultivator is earlier i think off a hand lift the cultivators are 52
youngster
04-29-2004 17:24:59
wow what year is yours mine is totaly difrent.
