Mounting brackets for MF265
Markus Sperling
04-27-2004 05:49:25
I purchased an Allied 594 loader and require mounting brackets for my MF265. I have conflicting information regarding the correct mounting brackets.
Has any one mounted an Allied 594 on a MF265 and what mounting brackets did you use? Any information would be very helpful...Thanks
Phil in MS
04-27-2004 06:07:02
 Re: Mounting brackets for MF265 in reply to Markus Sperling, 04-27-2004 05:49:25
I just put a Bush Hog loader on my MF255. In searching for this loader I found that the Bush Hog bracket is the same for the 255, 265 and 275. I just looked up your tractor on the Allied site and the mounting bracket for a 595 loader which likely replaced your 594 for the 255, 265 and 275 is the same. It also indicated that the MF 261 used the same bracket but I am not sure if that is correct. Good luck in your hunt.
