Hi Guys, Thanks for the all the information, I'm going to need as much help as I can get. Sibby; I am near Canberra. Where are you? The hurry to load this machine...I bought it from a farmer at Bredbo and he wanted it off his block. The machine is now on my block. I managed to drive it out to a decent road that a tow truck could use, about 10 k's. I checked the oil on level ground and it was on the bottom line so took a calculated risk that it was sufficient. The dipstick just doesn't look right. I don't know anyone with a machine like this. I am reasonably mechanically inclined but my field of expertise is cars. I'll figure it out if I can get an operators and a service manual. My guess on the brakes (without pulling the water filled wheels off) is the left one has fallen apart in the drum, there is a clunking sound when I hit the left pedal, retaining srpings?? The right one needs adjustment before I can guess, the pedal hits the "floor" before any shoe contact is made. The hydraulics (3PL, draft and FEL) work fine, the engine leaks oil, the transmission is weeping fluid and one of the hyraulic rams on the loader leaks a bit. I suspect the loader is home made. The beast is addicted to Aerostart, an issue I will have to rectify. I can't see a glow plug in the manifold (is this possible?), it's a 4 cyl diesel (I'll get the engine ID numbers tomorrow) with the manifolds and starter on the RHS and the injector pump and filters on the LHS. A standard diesel?? The ID number on the plate is SDM ??1165, the first 2 numbers are badly scratched. The rear guards and bonnet assy are red, the engine, trans and diff are grey. Bob from UK suggested an FE35 which I suspect is true. Should this model have a 2 stage clutch? I figured $3,500 was a good buy for a running machime with FEL, what do you think? Kind Regards Michael Oakes
