MF 65 trans fluid
Tractor Dan
04-25-2004 06:37:15
I recently discovered my MF 65 had milky transmission fluid. From reading other messages on this website I see recomendations for Walmart GL-1 and Multi 134. Neither is available locally. My Mobil wholesaler put me on the phone with an "engineer". I told him I needed GL-1 spec and he said Mobiltrans HD, SAE 50 was a GL-1 spec($31 for 5 gallons). My NAPA dealer called the Valvoline "engineer" and he said they have a product called "Tractor 90" ($50 for 5 gallons). Anybody have an opinion on whether the Mobiltrans HD 50 is OK and that what I want is really GL-1?
tractordan
04-27-2004 16:50:37
 Re: MF 65 trans fluid in reply to Tractor Dan, 04-25-2004 06:37:15
After further research I think the "engineer" was wrong about Mobiltrans HD 50.
Jeff-oh
04-26-2004 10:58:52
Dan, I would not write off the Mobiltrans HD yet. You want 90 wt straight mineral oil meeting the GL1 specification. That said, I have also heard, here on this site, that 90wt mineral oil is equivelent in weight to a SAE 50 wt. oil. That said, it is up to you to really question the manufacturer to verify that the two numbers are equivelent. But it is possible that they may be.
What you do not want is a SAE 90 wt. gear oil.
Jeff
tractordan
04-26-2004 14:24:27
 Re: Re: MF 65 trans fluid in reply to Jeff-oh, 04-26-2004 10:58:52
Thanks for all of the input from all those replied to my posting. It's hard to imagine how far from nowhere I live so you have to believe I couldn't find any straight 90 around. I did spend a lot of time on the internet and learned a whole lot about GL-1 petroleum products. The main thing is that they don't have additives that can wreck "yellow metal" parts, they are actually made from refining oil, and they are for low stress gear lube. Lots of companies make stuff that will work in my MF65 (famous last words).
Randy
04-26-2004 07:02:35
Shell sells a product called Dentax. It will fit your needs. It's GL1, and 80w90 weight, which will make it a little easier to pump in the winter cold. I use it.
tractordan
04-27-2004 16:52:16
 Re: Re: MF 65 trans fluid in reply to Randy, 04-26-2004 07:02:35
Randy - could you mean Donax? and is it Donax TT?
dirthog
04-25-2004 07:03:10
You should run GL1 spec Pure Mineral Oil, 90 wt. I got mine at a MF dealer, although napa said they could get it for me. My tractor has run fine for forty years, my personal opinion is that I would keep looking for the gl1 mineral oil. If you park your tractor outside throw a cover over it when it rains, lotsa time's water can get in around the shift boots.
