Will a MF35 handle a tiller?
Ron
04-22-2004 23:01:12
I am currently looking at a MF35 with the perkins. Will it handle a 6' tiller? It will be replacing an 8n and the one big item I am looking to do is till instead of plow.
Thanks
Ron
Oh YEA!!!sibby(Aus)
04-25-2004 22:14:22
 Re: Will a MF35 handle a tiller? in reply to Ron, 04-22-2004 23:01:12
If you wanna work 2" deep!!!
U.P. Tractor Dan
04-25-2004 17:23:55
Don't do it. Get a MF 65 or better. There are some good ones on e-bay now. The MF 35 isn't much "bigger" than the one you are replacing.
Ray A in N.J.
04-25-2004 11:14:51
Ron, I heard one time that you need about ten horsepower per foot on a tiller which would put a six foot tiller at 60 horse tractor.
No,
04-23-2004 07:08:26
..probably not as well as you'd like. If you're working previously plowed ground then it should be OK. If it's sod, you're in for a "beating". Even in Low 1st our 6 foot tiller is all the 245D wants. I would try it out(rent, borrow) first to see if 'you' like it or not.
Peter, U.K.
04-23-2004 02:35:52
Shouldn't be a problem, it's a gutsy little tractor.
aljorge
04-26-2004 18:21:52
 Re: Re: Will a MF35 handle a tiller? in reply to Peter, U.K., 04-23-2004 02:35:52
It depends on how heavy your soil and your tiller. We use a 60" E series Howard tiller on heavy soil and it works good. If you go to a light or home owner model you could get by with a 70" tiller. A heavy tiller would need more power. But never put the 8N 25Hp Mf35 33hp on the same level.
