444 engine
matt
04-22-2004 14:23:23
i was wondering what would a none running massey harris 444 engine be worth. I think it spun a bearing and that is all that is wrong with it?
I might purchase it if i can get it reasonably.
thanks matt
David B
04-23-2004 20:12:13
 Re: 444 engine in reply to matt , 04-22-2004 14:23:23
444 engines are great engines. Do you have a need for it, parts are harder to find then for the 260 cube inch 44 engine. I don't know what you use if you want to replace the rear main oil seal. I know on the outside you can spot the 444 engines if you need to make everything original. Over size 4 inch 44 pistons inter change with the 277 engines but the sleeves are different, and so are the main bearings, and REAR OIL SEAL.
