massey ferguson 135 no start
gary
04-22-2004 05:20:43
Having trouble getting this thing started. It's probably been 3 years since it was last ran, 25 since I last ran it. First I checked for spark...had none. Filed the points and now have spark. Fuel was old so I removed the sediment bowl and drained the tank from there. I also removed a screw from the bottom of the carb and drained there. Put in 1 gallon of clean gas. I cranked and cranked on it, nothing. It will pop if I shoot a bunch of ether in it. No fuel seems to be getting to the carb. I noticed what I assume is a valve on the housing above the sediment bowl. It was pointed straight up. I tried it at 3,6, and 9 o'clock positions and still never seemed to get fuel to the carb. What am I doing wrong?
Free Bird
04-22-2004 08:32:37
 Re: massey ferguson 135 no start in reply to gary, 04-22-2004 05:20:43
Watch out with that either, it could bad for you engine..... .
Tim
04-22-2004 08:21:53
Gary,
I just had the same thing happen to me except mime had only sat up for two years. My problem was the electric solenoid on the bottom of the float bowl had rusted and was not allowing fuel into the jet. Cleaned the solenoid and the tractor started right up.
gary
04-22-2004 19:04:16
 Re: Re: massey ferguson 135 no start in reply to Tim , 04-22-2004 08:21:53
Thanks, I wasn't aware of a solenoid controling fuel. It'll probably be a week before I get to look at it again but that's the first thing I'll check. If I strike out I'll be back with more clues.
