Fuel pump MF135
IMKCMAC
04-21-2004 17:07:18
Can one put an electric fuel pump on a continental 4cyl gas motor with the gavity flow system?What pressure pump would you need to use?My concern is to much pressure for the carb since it wasn't designed for a fuel pump.
I have one place on property where it meets the road that has an incline and if fuel isn't so so i run out of gas.
kjm
04-22-2004 18:36:17
 Re: Fuel pump MF135 in reply to IMKCMAC, 04-21-2004 17:07:18
You might check the float level in the carb,if it is to low it can cause your problem. good luck kjm
COSMO
04-22-2004 05:47:17
Even if you did put one on wouldn't you still draw fuel from the same gravity port? Sorry, don't mean to be sarcastic, but it would not be of any benefit.
Ray,IN
04-21-2004 20:50:32
I don't think the carb float valve is made to withstand a pressurized system. Just how much incline are you speaking of? I can't imagine an incline steep enough to starve the engine of fuel and still be safe for driviing a tractor on it. The gas tank is directly above the carb, and if you have 2-3 gallons of gas in the tank the tractor cannot safely be tilted enough,unless you have an obstruction in the fuel delivery system that is barely allowing enough fuel to run the tractor on level ground. The "pot metal" that the sediment bowl frame and carb are made from doesn't like water, and will corrode badly if allowed to remain in contact with water for extended periods causing many problems. Sediment that gets through the filter bowl will settle in low spots in the fuel line obstructing flow there also.
MIKE
04-22-2004 06:16:23
 Re: Re: Fuel pump MF135 in reply to Ray,IN, 04-21-2004 20:50:32
I HAD THE SAME PROBLEM YEARS AGO WITH A 8N MOWING A LEVEE.THE BOWL IS ON THE LEFT SIDE OF THE TANK ON MY 135 SO YOU NEED TO GO IN THE DIRECTION THAT KEEPS THE GAS ON THAT SIDE.EVEN IF YOU ARE LOW ON GAS IT WILL BE ON THE PICKUP SIDE. HOPE THIS HELPS
