Help needed on MF 180 tractor with a stuck transmi
Randy
04-20-2004 19:22:40
We have a MF 180 diesel. Recently the transmission stuck in one of the foward gears. From the speed, it appears to be second.
This tractor has a shift lever for high/low range in a straight slot, and a shift lever for reverse and 1-3 forward in an H shape slot.
The high/low range works fine. Neutral in high/low works also.
The forward/reverse shift lever will not pull out of gear. While there is slight play, it is near the center of the H slot. I can move it a small distance left and right, but not up and down to bring it out of gear.
I have taken the upper housing off the tractor for a better view, although it is still hard to see exactly what is happening.
The shift rods are connected down to the transmission housing.
I don't know if the problem is in the center shaft that the shift rods rotate on, or in the transmission itself. While I can work on the basics, I am not a mechanic.
Can anyone offer advice as to what corrective measures could be tried?
Thanks
dirthog
04-21-2004 04:08:45
 Re: Help needed on MF 180 tractor with a stuck tra in reply to Randy, 04-20-2004 19:22:40
Do what ray said, 99% sure you don't have a big problem. About a miniute with a screw driver should have you going.
Ray,IN
04-20-2004 20:02:07
Visit Big Dean's website and read the solution to this fairly common problem. This is the address to his photo/tips page: http://photos.yahoo.com/bigdean63
