MF65 Thermostat
Greg
04-20-2004 10:23:02
Just wondering if I need to run a thermostat in my 65 it is diesel the old guy i bought it from didn't. But I was concerned that it might cause it to draw moisture by not using one. And if i should what temp. should i get for it?
david
04-21-2004 05:24:00
 Re: MF65 Thermostat in reply to Greg, 04-20-2004 10:23:02
greg, you should run a thermostat in everything. It reduces wear and helps boil out moisture. A 180 or 190 degree is most common. good luck, david
