massey ferguson 65 hydrulics
Drew
04-20-2004 03:05:29
Have Knocking noise in hydrulics when under load,but only with heavy load (rotory hoe).Have reconditioned hydrulic pump only month ago,new valve chambers,valves,pistons,cam blocks etc.Every thing working fine lifting,lowering,mid lift under pressure.May be control valve adjustment might be wrong.Any help much appreciate.
Cheers Drew from oz
sibby(Aus)
04-20-2004 05:14:59
 Re: massey ferguson 65 hydrulics in reply to Drew, 04-20-2004 03:05:29
DREW, the noise you hear is normal on Massey when the hydraulics are loaded up with weight. Were the hyd pump dowels o.k.? (they support the pump on each side of trans housing and retained by two 5/16" studs.)If they are worn the pump jumps about a lot more and rattle worse. cheers!!!
