MF35 Distributer
Dominick Corcog
04-19-2004 16:48:04
Help'' I am not a mechanic and don't know much about tractors but my dad has a MF35 He can't see very good but he put new wires on it anyway. Then called me to look at it. It would start but had a bad miss..I found the fireing order and got it running but still misses but not as bad..I still feel that the wires are wrong on the cap. How do I find #1 on the distributer cap can anyone help...Thank You
Oldfarmboy Jim
04-20-2004 22:23:16
 Re: MF35 Distributer in reply to Dominick Corcoglioniti, 04-19-2004 16:48:04
Dominick, The distributor rotor moves in a counterclockwise direction on this tractor. It's common to find them wired as if the rotor went clockwise. They'll start, but they run pretty badly if that's the problem. Jim
parts man
04-19-2004 20:17:57
Pull #1 plug, stick you finger in the plug hole, turn the engine BY HAND until you feel comprssion agains your finger. Find TDC, #1 position on the cap is where the rotor button will be pointing to. Follow the firing order in the direction of the rotor travel.
