governor
Steve Smith
04-19-2004 13:28:18
I have a Massey 165 gasoline engine ~ date 1968. The engine is a Perkins. The governor does not work properly on the tractor. I have made the adjustments on the adjustment arm but I have been told that I may need to rebuild the governor in the housing. What do I need to do? What parts must I buy to make this tractor run like it did when I bought it? Also the exhaust manifold has started to leak. What is the best way to remove the exhaust manifold without breaking off the bolts and does the exhaust manifold have a gasket between the block and the manifold?
