Massey Ferguson 35 high oil pressure problem`
Pat Shiels
04-19-2004 04:12:44
After recently changing the oil ive found that the oil pressure is now very high and stays constantly high when i use the tractor. I used the recommended Duckhams oil for diesel engines. Does anyone have any ideas why this is happening?
garvas
04-19-2004 07:01:06
 Re: Massey Ferguson 35 high oil pressure problem` in reply to Pat Shiels, 04-19-2004 04:12:44
Sounds like the gauge decided to go south, had this happen one time with a gas tractor. Changed oil and pressure pegged gauge. Changed unit and all returned to normal.
Pat shiels
04-19-2004 07:10:04
 Re: Re: Massey Ferguson 35 high oil pressure probl in reply to garvas, 04-19-2004 07:01:06
Thanks a lot Garvas. Ill take your advice and try a new gauge. Even tho the gauge is showing a high pressure reading the tractor itself is running as smoothly as it did before the oil change which is pointing towards the gauge being faulty. Once again thanks for responding
