1952 Pony
Dale
04-17-2004 16:47:23
Can anyone tell me how the breaking plow connects to the Hydraulic lift. A picture would be great. Thanks for your time. Dale
John
04-23-2004 07:48:23
 Re: 1952 Pony in reply to Dale, 04-17-2004 16:47:23
Hi Dale
If you have the square style draw bar swing it to the front of the tractor two bars bolt to the draw bar and hook to the front hydraulic arms this controls the depth or tilt of the plow. The plow hooks to drawbar with a clevis around the drawbar that will slide back and forth that locks into a pin on the bar which controls the furrow width. an arm and chain with about a 2" ball on the end lifs the plow on the rear right lift arm. When i get my plow on i will post some pictures in the implement photos. Hope this helps for now John
wademarch
04-18-2004 04:42:08
Dale, if you find out let me know. I have the rear lift(hyd), but no plow or info. If I learn anything I'll tell you. Mine is a 52 as well. Does yours have a sickle mower on it? Mine came with one in pieces and I am struggling to figure it out. I think some pieces are missing. Good Luck.
youngster
04-18-2004 06:06:56
 Re: Re: 1952 Pony in reply to wademarch, 04-18-2004 04:42:08
ok i will tell you how to hook it to hydralics if you show me how it is hokked to tractor. and draft lever. post pic if this explanation does not work. you should have a dar that baltos to the plow behind the sod cetter with a crank that contrlos the tilt of the plow. and that crank should go through slider on the lift arm.
kim coward
04-26-2004 08:06:27
 Re: Re: Re: 1952 Pony in reply to youngster, 04-18-2004 06:06:56
hi: glad to see some pony people, hope to get one this summer, im new at the game also. kim
