Final drive oil
Don H
04-16-2004 12:29:59
I have a '70 model 165. I have the IT manual that shows the volume, and type of oil to use in the planetary gears on the rear axels. I see the plug where you add the oil but can't seem to locate a drain plug. There is a small screw on the bottom of the housing. Is that the drain plug? Thanks in advance for any help.
sibby(Aus)
04-16-2004 15:53:00
 Re: Final drive oil in reply to Don H, 04-16-2004 12:29:59
Don, the drain plug is only small, and yes it is on the bottom of the housing. you should first run the tractor around a bit to warm up old oil and then drain it. cheers!!
