MF1150 hydraulics
grainfarmer
04-15-2004 11:20:13
Any idea what would cost a new hydraulic pump for MF 1150? Or repair set if theres one?
I'm going to buy a 1150 that has bad hydraulics and it might be the pump.
Thanks
Rob
04-18-2004 18:28:42
 Re: MF1150 hydraulics in reply to grainfarmer, 04-15-2004 11:20:13
Which pump are you talking about? There are two on a 1150. The front pump is for high pressure functions and the charge pump is for low pressure functions like multi power and pto, it also supplies the front pump with oil.
Rob
grainfarmer
04-19-2004 11:37:30
 Re: Re: MF1150 hydraulics in reply to Rob , 04-18-2004 18:28:42
3-point and auxiliary hyds doesn't work properly. So I guess its the front pump. Or could it be the charge pump - how does it effect to the front pump?
chuckinnc
04-16-2004 10:02:49
Are you sure its bad, the lift controls had problems. Both of mine quit so I plumed the line from the lift cyl. to the remote valve control. That was many years ago, I still use it that way
Its position control only, no draft this way.
grainfarmer
04-19-2004 11:40:26
 Re: Re: MF1150 hydraulics in reply to chuckinnc, 04-16-2004 10:02:49
I dont know exactly whats wrong because I havent even seen the tractor. Thats just what the dealer told me. I understood that the auxiliary hyds doesnt work on it either.
Thanks
