MF-135 foaming trans oil
JimT CA
04-13-2004 18:00:52
Hi
I had IPTO sliping...removed hydraulic cover
removed IPTO pump strainer which was completely
clogged and damaged. I installed a new strainer
put oil back and started engine...oil is foaming
like crazy out of the PTO releif valve when I
engage the pto lever pressure goes in the cluth
park and no foaming.
Any ideas ???
Thanks in advance
JimT CA
Del
04-14-2004 08:08:21
 Re: MF-135 foaming trans oil in reply to JimT CA, 04-13-2004 18:00:52
A little water will cause foaming. I had a MF 35 once that the rubber boat around the gear shift lever was missing and let water in and it foamed pretty badly.
Tom
04-14-2004 04:54:01
You say you "put the oil back" do you mean you put the old used oil back in? If the screen was clogged up, then the fluid should be changed, run about 40 hours and changed again to clean up the system.
JimT CA
04-14-2004 07:23:00
 Re: Re: MF-135 foaming trans oil in reply to Tom, 04-14-2004 04:54:01
No....
I used wrong expression by put oil back
I should say i put new oil
The oil I removed has only few hours I changed it
when IPTO started slipping. The oil I removed
was carried to oil recuperation center.
I'm not so stupid to reuse the oil that clogged the filter.....
