FE35 vs MF65
Craig in NZ
03-22-2000 02:38:54
Hi Folks,
Opinions please - what are the pro's and con's of an FE35 (which I have) vs a MF65 (which is going cheap). Is one known to have a better name than the other and if you had to choose which one would you pick?.
Secondly - how many litres (or gallons) does the FE35 fuel tank hold?. Thanks as always.
Clarence Carhill
03-22-2000 17:20:09
 Re: FE35 vs MF65 in reply to Craig in NZ, 03-22-2000 02:38:54
Craig... I have a MF65 gas and it's a nice tractor with enough HP to run a round baler... But It's longer and doesn't turn as short... It's heavier and steers harder... and it's a Gas Hog...
Mike from Ontario
03-22-2000 04:47:27
Craig
The FE35 is a good tractor, I have one myself, but the 65 is of course a larger tractor and more versatile depending on your needs.Being a larger tractor of course it has more horsepower, probably around 60hp compared to 30hp of the FE35.Itmay also have hydraulic remotes on it which you won't find on any FE35. Bigger tractor if you need one, but if you only have a couple of acres you can probabably get by with the FE.
Mike Leggett
