MF 165 PTO brake
Richie MaGoo
04-09-2004 22:41:46
T'was looking at an MF 165 today. The PTO kept turning, regardless of whether the clutch was in or out. The owner says T'is a busted PTO brake..... I think it's the 2-stage clutch. Anyway to tell for sure?
MB
04-11-2004 06:50:47
 Re: MF 165 PTO brake in reply to Richie MaGoo, 04-09-2004 22:41:46
You can't stay away from those Massey's, can you? Should've kept that 85 ;-) Good Luck on the search for the next one.
Richie MaGoo
04-11-2004 09:15:20
 Re: Re: MF 165 PTO brake in reply to MB, 04-11-2004 06:50:47
Good memory!, Marty, is it?
Ah, yes...my first tractor- the MF85 with trip-bucket loader! If it wasn't a gas job, i would've kept 'er!
No complaints with my Fergie TO-20....just need something a little bigger. Fergie works just fine, but I'm pushing her....often operating at full throttle, burning lots of gas, and not having enough power sometimes to make a clean cut with the bush-hog through the thick stuff (especially when going up a steep hill)
The nice thing is, I'm not desperate for another tractor- so I can take my time, and wait for something good at a fair price..... and maybe ten years from now, i'll find something! (With most of the farm auctiuons around here being on Saturday- and that being the one day that i can't attend, it makes it hard to get anything!)
Take care,
Rich
MB
04-11-2004 11:29:41
 Re: Re: Re: MF 165 PTO brake in reply to Richie MaGoo, 04-11-2004 09:15:20
Yes, it's me. You'll find one soon enough, there are lot's more out there that aren't "Saturday Sale Specials"! If I see a bargain I'll holler.
Richie MaGoo
04-11-2004 14:41:22
 Re: Re: Re: Re: MF 165 PTO brake in reply to MB, 04-11-2004 11:29:41
Hey, thanks!, Marty.
I'm basically looking for a diesel between 35-60 HP- no particular brand or model. (Uh...maybe not a Belarus though!)...for not much more than $4K.
I had someone wanting to buy my Fergie for good money...but I lost him, because there aren't many tractors for sale around here in my price range.
Rich
Bill B
04-10-2004 20:52:58
Hi, I have a 165d that the PTO turns all the time unless it has a load on it. Works OK other wise, I use the PTO all the time. Bill
Richie MaGoo
04-10-2004 21:28:19
 Re: Re: MF 165 PTO brake in reply to Bill B, 04-10-2004 20:52:58
Hi There, Bill,
Sounds like your PTO brake just needs adjusting.
On the one i was looking at, the PTO turned with power...even with a load.
Rich
(You're not from Austalia or New jersey or anywhere I can make fun of?)
sibby(Aus)
04-09-2004 23:05:18
Richie, does it have two or three positions on pto lever? if two positions its ipto with brake, three position its engine speed in back position, neutral in middle, ground speed with lever pulled forward. no brake on 2 stage, could have a stuck pto plate or pto clutch needs adjusting. cheers!!
Richie MaGoo
04-10-2004 12:17:10
 Re: Re: MF 165 PTO brake in reply to sibby(Aus), 04-09-2004 23:05:18
Thanks, Sibby!
It has a two position lever.
It could still be the clutch causing the problem though, right? I was just wondering if there's anyway to tell, without taking it apart.
The motor hums like a didgerydoo- but I wouldn't want to pay fair market value for a tractor that needs to be split.
Thanks, mate!
G'day!
Rich
(sorry....I couldn't resist!)
sibby(Aus)
04-10-2004 13:24:14
 Re: Re: Re: MF 165 PTO brake in reply to Richie MaGoo, 04-10-2004 12:17:10
Richie, youre right on track cobber!! no easy fix for an ipto, take a shortcut and it will boomerang, (come back to haunt you, matey). could be buckled drive plates in pto pack. could it have been caused by oil starvation e,g, choked pump strainer, low oil pressure to pack? good luck and cheers!!!
jake
04-11-2004 05:37:34
 Re: Re: Re: Re: MF 165 PTO brake in reply to sibby(Aus), 04-10-2004 13:24:14
Hi!
My mf 168 also has this problem, when the oil is cold and there's no load(or light load only) on the p.t.o, the pto shaft keeps turning. Only problem it usually causes is that you have to shut off the tractor to connect something to the p.t.o. Or if it's warm you can usually stop the pto by hand(be careful with this).
sibby(Aus)
04-11-2004 05:59:09
 Re: Re: Re: Re: Re: MF 165 PTO brake in reply to jake, 04-11-2004 05:37:34
Jake, sounds like you like living in the fast lane. i wouldnnt recommend this at home. cheers!!!!!
