MF 135 leaking......
Lee-135
04-07-2004 20:03:41
My 135 deluxe (diesel) has just started leaking a small amount of hydraulic fluid (about an ounce)at the hydraulic port, on right side of top cover,at start up and then it stops ...only does it at start up. Nothing else seems to be wrong with hydraulics other than that messey leak. Any help on the matter would be greatly appreciated!!! THANKS.
sibby(Aus)
04-07-2004 20:23:05
 Re: MF 135 leaking...... in reply to Lee-135, 04-07-2004 20:03:41
Lee, do you mean the rectangular transfer cap on top of standpipe? if so remove cap and replace the o,ring in the cap and on the top of standpipe with a back/up washer. the o,rings are same size.regards, sibby.
Lee-135
04-08-2004 14:47:52
 Re: Re: MF 135 leaking...... in reply to sibby(Aus), 04-07-2004 20:23:05
..looked under there today and the o rings were in sad shape ..... ..will replace...Thanks very much sibby for your reply !! Lee
