Head Question
Green 88
04-07-2004 19:21:40
Can a Massey 1080 head be used on an 1100?
MF Kid
04-08-2004 06:52:21
 Re: Head Question in reply to Green 88, 04-07-2004 19:21:40
No. The 1080 has a 4 cyl and the 1100 is a 6 cyl. If you need a head you have to use a 354 perkins 6 cyl head.
Starving farmer
05-13-2005 16:32:11
 Re: Re: Head Question in reply to MF Kid, 04-08-2004 06:52:21
I have a older MF 1080 with a three cylinder Perkins and I need a water pump hoe do i find out the year to order parts.
Hey C'mon ....
04-08-2004 09:16:01
Wadaya mean you can't use it, sure you can! You'd just have two cylinders on the big one not working that's all. Something is better than nothing don't ya think?
sibby(Aus)
04-08-2004 16:51:51
 Re: Re: Re: Head Question in reply to Hey C'mon ...., 04-08-2004 09:16:01
never knw, if you soak it in hot water it might strrrrr etch a bit and fit, bolt it up real qquick like before it shrinks. another way would be to cut another head in half and weld em together, then you have 2 cyls left for next time!
sibby(Aus)
04-07-2004 19:27:23
are you talking about diesel engines? one is a 318 cu.in. 4 cyl, the other is a 354 cu. in. 6 cyl engine.get a tape measure and measure length.
