MF204 Question
Dave Barkley
04-07-2004 17:47:47
Does any possibly know which spark plug wire goes to which hole on the distributor.
My tractor quick working last year and with all of my other projects I finally got around to working on it. I put new points, condensor, rotor, coil and new plugs in it. It will not fire at all. Not sure if the Carb needs to be cleaned or if I put the spark plug wires in the wrong order.
Thanks for any information you can give me.
Dave
rod
04-08-2004 10:09:20
 Re: MF204 Question in reply to Dave Barkley, 04-07-2004 17:47:47
I have the MF 204 manuals the firing order is 1342 if you need more info drop me an email.
regards
rod
Dave barkley
04-08-2004 10:11:19
 Re: Re: MF204 Question in reply to rod, 04-08-2004 10:09:20
Thanks a lot. This has been driving me nuts.
Hopefully tonight I can get it running.
rod
04-08-2004 10:16:58
 Re: Re: Re: MF204 Question in reply to Dave barkley, 04-08-2004 10:11:19
look at how the rotor button turns with cap off it is easy to get wires on wrong I think you will find rotation is counter clock wise I have the complete timing procedure I can scan and send you.
regards
rod
