front axel support casting
rusty
04-06-2004 13:12:02
I need a front axel support casting for a MF 30B
Where can I find one used and what do I look for. I broke the axel out of the one I have now and don't want to buy a bad one. Can the casting be welded?
sibby(Aus)
04-06-2004 13:34:14
 Re: front axel support casting in reply to rusty, 04-06-2004 13:12:02
rusty, i have seen them welded before when they have cracked and aand broken out around the pivot pin holes. care is needed in preparing and setting up job, pre heating and keep warm after welding to avoid cracks. vee out well before welding with high nickel rods. cheers.
Alberta Mike
04-06-2004 13:33:58
Since the casting is pretty easy to remove and repair, why not repair it? I would suggest though that you take it to an experienced cast iron repair shop, that way it's done right. They grind the whole broken area out and do it properly with heating ovens, slow cooling, probably stronger than the rest of the casting.
