MF 165
Harold
04-06-2004 11:20:28
I just purchased a 1967 MF165 with a independent PTO and Multi-Power and I can not shut the PTO off and the Multi-power does not shift any help or any idea's of what could be possible wrong would be appreciated.
Thanks
Harold
Big Dean
04-06-2004 11:39:21
 Re: MF 165 in reply to Harold, 04-06-2004 11:20:28
If the pto will stop turning when you have it hooked to a lmplement but not when it has nothing on it your problem is probably the pto brake. If it will not stop turning with an implement hooked to it it is probably caused by warped clutch pack discs & plates. The multipower not working could be caused by the shift linkage out of adjustment, worn clutch pack discs, leaking seals or uaually both.The Independent pto & the multipower use the same pump & relief when you have both of those options.If I can be of further help email me.
