oil pan removal MF 65
Greg Stanley
04-05-2004 06:26:44
I have a MF65 and I need to get the oil pan off. It appears to me that i have all the bolts out of the pan. I have the wedge out and the two bolts that go straight up under the wedge removed but the pan will still not move.??
If anyone has any sugestions i would really appreaciate any help.
Thank you,
Greg
C. T. in Oklahoma
04-05-2004 12:43:18
 Re: oil pan removal MF 65 in reply to Greg Stanley, 04-05-2004 06:26:44
Greg, On my 35, there is a bolt at the back of the pan (towards the seat/transmission) and we were going to force it, but I ran my finger totally around the pan and found it. It was kind of hidden. Just be careful. C. T.
jake
04-05-2004 11:24:49
if all the bolts are really taken off then i suggest you use a large hammer with a piece of log, and try to loosen the pan this way...
sibby(Aus)
04-06-2004 04:58:27
 Re: Re: oil pan removal MF 65 in reply to jake, 04-05-2004 11:24:49
greg, look towards front of engine, i think under generator, there is a spacer that MUST be removed and it will reveal a hidden bolt or stud. if you force the sump with it still in be warned it will break a piece of cast iron out of your engine block or sump. they do not require that much force for removal.
