Massey Harris 33
JakeDoty
04-02-2004 19:41:16
I have a Massey Harris 33G that I am restoring and have 2 questions, 1) I was wondering what it's number thing was like TO-20, TO-30, TE-20 etc., and 2) Where can I find the serial number? I have a manual and it says to look on the transmission housing top but the number there isn't and of the numbers that would be the serial number. It could only be 1)Year 1952: #1001, 2)Year 1953: #2055, 3)Year 1954: 6617, or 4)Year 1955: #9782
I attached 2 pictures of the tractor.
david B
04-03-2004 17:13:31
 Re: Massey Harris 33 in reply to JakeDoty, 04-02-2004 19:41:16
If it has a little after market lever that helps you shift pulley/pto lever in and out it may be under part of it. Alberta Mike is right, that number it's there.
Alberta Mike
04-03-2004 07:41:04
I'm not sure what you mean by it's "number thing" (eg. TEO20 etc .... those were Ferguson model numbers). Your tractor is a MH 33, it's as simple as that. The G indicates it was a gas version from the factory. The serial number is on the upper machined surface of the transmission/differential housing between the gearshift lever platform and the steel plate which covers the gears at the rear. It is hand-stamped into that upper machined surface near the left side (in the vicinity of the clutch pedal when it's in the out position). It'll be there, you'll have to hand scrape paint and crud away, use a wire brush. Sometimes the numbers are not stamped too deeply so you'll have to look hard.
