What is a MF 165 worth?
ShepFL
04-02-2004 11:54:41
Fair condition, 3pth. Rears need to be replaced. HP unknown, appears to be perkins dsl.Wife's girlfriend said her Granny wants to get sell, asked if I was interested. Not sure of worth or upside/downside to these rigs.
Thanks
Don-Wi
04-05-2004 20:35:55
 Re: What is a MF 165 worth? in reply to ShepFL, 04-02-2004 11:54:41
That should complement your 550 quite nicely if you get it. We have the gas @ 48 hp, the deisel is about 52 hp. The Multi-Power is a nice feature to have, makes it a 12 sp. in a 6 sp transmission. We used ours yesterday making holes to plant pine trees. Put a 10" post hole auger on the back, set the depth and punched 210 holes in about 2 1/2 hrs, with dual clutch pto. They are extremely handy tractors, and don't fight with the Ollie's. If in Fair condition, $4500-5500 should be about right
Best of luck
Donovan from Wisconsin
Ray,IN
04-02-2004 19:16:14
You can check the tractor auctions link at left for a ballpark figure, but the condition is unknown. Visit Big Dean's website for tips on buying a MF tractor, he has good advice for checking the condition of your prospective purchase.
Gary Cole
04-02-2004 13:03:19
They can go anywhere from $4000 up. Depends on condition and how bad you want it
sibby(Aus)
04-02-2004 17:34:23
 Re: Re: What is a MF 165 worth? in reply to Gary Cole, 04-02-2004 13:03:19
check for engine smoke, check air cleaner condition for dust, is it choked? does the power steering work,? is it leaking,? has it got power steering? do your main and p.t.o. clutches release and not slip under load? any oil leaks, engine, trans ,rear end ,planetary reduction units (epicyclics) mounted on end of rear axles with rear wheels bolted to them. if you grip top of rear wheels and push in and out, do you feel any excess play ? do the brakes work, if so how well? arethey wet or dry brakes? you need a serial number and engine type, 203 or 212 cu. in. to try and estimate model to give a fairer estimation. has it got m/p or auxilary remotes fitted. any one of these things can make abig difference to its value. if fitted with m/p, does it work?any component thats leaking or needs attention costs big dollars. hope this helps, regards, sibby.
Bob
04-02-2004 17:42:35
 Re: Re: Re: What is a MF 165 worth? in reply to sibby(Aus), 04-02-2004 17:34:23
203=diesel
212=gas
sibby(Aus)
04-02-2004 22:55:36
 Re: Re: Re: Re: What is a MF 165 worth? in reply to Bob, 04-02-2004 17:42:35
sorry bob, we only have the 203 and 212 diesels over here, the gas or petrol as we refer to them would be far too expensive to run.
