massey twin power
otto torgerson
04-01-2004 05:28:37
what is a massey twin power?
Alberta Mike
04-02-2004 10:26:03
 Re: massey twin power in reply to otto torgerson, 04-01-2004 05:28:37
The twin-power feature that was mentioned below (added RPM's for belt work) also kicked in when you shifted into 4th gear, obviously for higher road speeds when travelling.
D L
04-01-2004 17:14:32
If you are asking about Massey Harris twin power, DW has it right.
DW
04-01-2004 14:10:45
Twin Power was a Massey Harris feature during the 30's & 40's. It basically consisted of a two position throttle and an interlock between the governer and the transmission. The interlock prevented movement of the throttle to Twin Power position unless the transmission was in neutral allowing increased rpm/horsepower for belt/pto work. I believe some models could also use Twin Power in high gear. It is presumed that many operators bypassed the interlock to access the extra ponys all the time.
Fox
04-06-2004 11:07:33
 Re: Re: massey twin power in reply to DW, 04-01-2004 14:10:45
How do you know if you have Twin Power? Could it be a feature on my 1950 MH 44?
Jeff-oh
04-01-2004 07:13:54
Twin Power was a MF sales feature. It is the same as multi-power, the name changed with the times. It is basicly a second govener setting that allows the operator to "kick" the PTO into "high-gear".
Not a real expert here, but that is what I remember from the Big Massey Book I read in Dec.
Jeff-oh
David B
04-01-2004 17:56:50
 Re: Re: massey twin power in reply to Jeff-oh, 04-01-2004 07:13:54
Seems to me like the twin power feature and the two speed multi/power are two completely different things. The multi/power lets you shift under power with out clutching that actually changes the gearing while the twin-power just let you open up the governor for an increase in engine RPM's and wasn't supposed to be used during heavy drawbar work
sibby(Aus)
04-01-2004 06:13:26
otto, do you mean multi/power?
