44 3PT hitch
slowsmoke
03-31-2004 04:17:03
Might take the 3Pt hitch off a 44 and make it a puller. What's the thing worth (pump/hyd./hitch/all)? thanks
Gary (Ont)
04-01-2004 07:26:18
 Re: 44 3PT hitch in reply to slowsmoke, 03-31-2004 04:17:03
I got the complete hitch-all and hydraulic system for my 33 for $400. The only part missing was the original top link. The hitch-all was already off of the tractor but I had to remove the hydraulics.
velvet ride
03-31-2004 07:42:36
Unless the lift shaft is above the PTO housing, it is not "Hitch-All", which was the MH name
for the Cat. II 3 point, introduced in 1954 on
the mid-production models, of the 44 Special RC's. The classic 44RC's never had Hitch-All,
production ended by the time of introduction. It
was offered, for 33's,previous Specials, could have been adapted to a Classic 44 RC. As has been
stated on this site, numerous times, the 44 was
known to tear apart the pre-Hitch-All 3 points.
They were little more than modified 30 cultivator
lifts. If you have Hitch-All with it's 5/8" thick
lift arms, heavy lower & upper bracing, intact,
the price can range from 4 to 650 dollars. The
weak, earlier 3 point, is more parade hardware,
value 2 to 3 hundred, less pump.
