Z-134 gas engine - normal oil pressure
steve
03-30-2004 13:11:00
What should I see as a normal hot and cold oil pressure on a '58 MF50 with the Z134 Continental engine? I don't believe the engine has been rebuilt, but it is sound and not worn out.
Thanks,
Steve
TO35
03-30-2004 20:45:04
 Re: Z-134 gas engine - normal oil pressure in reply to steve, 03-30-2004 13:11:00
Steve , The manual says no lower than 15 psi. at
Idle and 20 to 30 psi. at 2200 rpm's. Oil pressure is adjustable by shiming the relief valve in the oil pump. I would not worry if your oil pressure is within + or - 5psi of specs. anything more or less than that can result in oil related faliures. anything close should not be a problem remeber your dealing with a 40 + year old engine that is going to have some wear on it. I have several 134's running at 10 psiat idle and 25 on the top...hope this helps...
TO
steve
03-31-2004 07:11:02
 Re: Re: Z-134 gas engine - normal oil pressure in reply to TO35, 03-30-2004 20:45:04
That's about what I'm seeing (based on my gauge) - 22 psi cold at some rpms, and at a slow idle, more like 15 half-warm. I'll recheck it with a gauge that has better resolution when the engine is hot.
Thanks for the detailed information.
steve
