Urgent! Mechanics please help!!!Massey Ferguson T
Maes
03-26-2004 20:26:27
I have a TO 35 that I cannot start. When I do get it started it runs hard for about 20 seconds and shuts off and will not run after that. All the fuel goes into the oil tank. Can you tell me what is wrong? Thanks
sibby(Aus)
03-27-2004 01:08:57
 Re: Urgent! Mechanics please help!!!Massey Fergus in reply to Maes, 03-26-2004 20:26:27
mae,by oil tank do you mean oil pan or sump on engine? sounds like you have a perished fuel pump diaphragm which you can replace or replace the pump which can sometimes work out cheaper if you dont feel confident in re/conning the unit and have someone else do it.there is a right way and wrong way to refit the pump as you can break the accuating arm if fitted incorrectly.your carby may need a good cleanout and kit fitted also.dont forget to change engine oil when its finished.cheers.
sibby(Aus)
03-27-2004 01:15:48
 Re: Re: Urgent! Mechanics please help!!!Massey Fe in reply to sibby(Aus), 03-27-2004 01:08:57
mae, do you have an up draft or downdraft carby? aussie models have updraft on theirs, if you have a downdraft i would go for the needle and seat in carby first, if not fuel pump first. good luck!
sibby(Aus)
03-28-2004 23:02:48
 Re: Re: Re: Urgent! Mechanics please help!!!Masse in reply to sibby(Aus), 03-27-2004 01:15:48
gee maes, cant be that urgentbuddy!
