MF165 Serial and Part Numbers
Dennis
03-25-2004 17:16:13
I have been fightin a hydraulic problem for a while now on this tractor, so I finally broke down and bought the repair manual from this sight, an owners manual an a parts manual. They give all kinds of useful info, but looking in the owners manual to find out where to find the serial number for this tractor, and on mine no numbers exist over the starter wher they show it. This is the same for the transmission and rear axle assembly also. N one of the numbers that I can see on these parts are even listed as options for serial numbers. I know that this tractor has the AD4 203 Engine, I can find that. To make this worse when I checked the parts manual to see if any of these numbers I found stamped on the tractor were maybe part numbers I found several of them but they were one number lower than the numbers listed in the parts manual. For instance on the engine head ther is a data plate saying that this is an AD4 203 engine and right below that it gives a part number of 37786240 and when checking the parts manual the only part number for this was 37786241. This same thing held true for the top plate of the pump cover, rear axles and the transmission housing, all one number lower than any listed in the manual. I know that this tractor originaly came from Canada if that makes a differance. Sorry for being so long winded but I need help. Im tired of this thing sittin idle.
Dennis
03-28-2004 16:07:27
 Re: MF165 Serial and Part Numbers in reply to Dennis, 03-25-2004 17:16:13
Thanks for the web sights I will give them a try. I check for the numbers around the brake pedal and the only thing I could find was a number K200S that was upside down behind the fuel filter. Behind the brake pedal was "E 51 P" and then below that was a number 8 with a diamond logo next to it. I am still looking for any other suggestions on where to find the serial number for this tractor. Right now I just want something as simple as a hydaulic filter so that I can at least make it mobile again.
BOB UK
03-28-2004 04:00:22
Hi Dennis
I would suggest you send an email with your problem to Sparex, they have branches in UK, USA and Canada and do help in supplying parts, it's got to be worth a try' also Perkins engines.
The web sites are at the following
Link
www.sparex.co.uk for England
www.cefs.com for Canada
www.sparexusa.com for USA
Hope this is of help,
BOB UK
bob
03-25-2004 19:54:47
ya, it was probably made overseas. they used slightly different part #'s. Check the side of the tranny below right foot brake for tag.
