mf 202
jack
03-24-2004 20:30:34
I am looking at a 202 with hoe and loader.It has what looks like a 3 pt ,but do not know if it is complete and how to operate it,neither does the guy that owns it.
everything else looks and runs good.He wants 2k for it and not sure it is a deal or not.
Are there many probems with this rig? Also looks like new rears on it.
thanks for any info.
Karl
03-25-2004 08:51:26
 Re: mf 202 in reply to jack, 03-24-2004 20:30:34
The MF202 is powered by a Continential Z134 engine. It's rated about 40hp and as far as I know has no unique problems. Look for all the usual things that you'd look for in any used tractor. Check the pins & bushings in the loader and hoe for excessive wear. If everything works, grab it for that price. I have one with a loader and hoe that I use all the time. It's a great little tractor. I also have all the manuals for the tractor, loader, & hoe. Let me know if you need more info.
jack
03-25-2004 11:51:22
 Re: Re: mf 202 in reply to Karl, 03-25-2004 08:51:26
thanks for the info. Looks all ok.Any idea on the 3pt setup or use?
thanks
Karl
03-25-2004 19:31:53
 Re: Re: Re: mf 202 in reply to jack, 03-25-2004 11:51:22
It should have rockshaft arms sticking out of the lift cover just behind and below the seat. Then there are connecting rods that attach the rockshaft arms to the 3-pt hitch arms that are connected to the differential housing just below and behind the axle castings. Hydraulic pressure for the 3-pt comes from a piston pump located in the bottom of the transmission. The 3-pt hitch is controlled by the levers to the right and just below the seat. I can send pics of mine if you'd like.
