MF65
homer long
03-23-2004 05:57:41
My MF65 gas has a squeaking noise I beleive is coming from water pump doesn't heat up and don't seem to be getting any louder even at higher rpm's Is there a bearing that could be replaced easily
Tom in Wis.
03-23-2004 15:11:18
 Re: MF65 in reply to homer long, 03-23-2004 05:57:41
You can't replace the bearing but last week I replaced my 65's water pump. Got mine at NAPA with exchange, they pressed my pulley off and on to the new one for $27. They got the pump in 1 day. What a bargin.
Ray A in N.J.
03-23-2004 16:16:40
 Re: Re: MF65 in reply to Tom in Wis., 03-23-2004 15:11:18
Before you assume it is the water pump making the noise, check out the front bearing in the generator first. put some light weight oil in the oiler cup and see if the noise stops. I have 5 60's model masseys and I have never had the water pump squeak but the generator has. Had to replace the gen. bearing.
