240 power steering pump
david
03-19-2004 12:15:02
can the seal go out on the pump and cause the pump to leak into the crankcase? What kind of pressure should it run? Is the relief valve in the pump or where?It turns fairly easy to the left and hard to the right. no leaks. can't hear fluid by-passing in steering cylinders. Any help is appreicated. Thanks, David
