MF 10 Lawn Garden Tractor W/Front Engine
David
03-19-2004 05:03:45
Anyone know where a picture of this tractor is?
What transmission do they have? Is it the same one as a John Deere 110?
Thanks for any information. I have one I want to fix up and can't find any information on it.
Thanks,
David
Michael Soldan
03-20-2004 13:58:40
 Re: MF 10 Lawn Garden Tractor W/Front Engine in reply to David, 03-19-2004 05:03:45
David , the transmission is mounted rear, and both rear axles run out of it, it is a variable drive trans that is driven by belt, there is a transmission split sheave and a variable sheave near the front, the variable drive comes from movment of the lever on the right side, this moves the sheave and the belt runs higher or lower on the pulley , depending which way you shift, this gives you more speed less power or more power less speed as you shift up or down.I doubt that any JD trans would interchange with out a lot of changes to the rest of the drive. Yours may simply need a belt, or adjustment of the variable speed, your actual transmission may be fine..... .Mike in Exeter Ontario
David
03-22-2004 04:03:08
 Re: Re: MF 10 Lawn Garden Tractor W/Front Engine in reply to Michael Soldan, 03-20-2004 13:58:40
Michael,
Thanks for the reply. I guess I should have been more specfic. The shifting lever at the trans is broke off at the pivot and was wondering where to get one. I was thinking it probably is used in other tractors.
Thanks,
David
