serial #
derf
03-18-2004 11:37:16
gisf 50042P Its a 44 diesel ,Why the P after the serial number. ONT.
David B
03-18-2004 18:01:55
 Re: serial # in reply to derf, 03-18-2004 11:37:16
The P at the end of the serial number tells you what injector pump your tractor was made with. The P means you have a P.S.B. pump and if it had a letter A it would mean you had a A.P.E but they are later pumps, probably have to get into a late 44 Special or a 444 for this pump. On the P pumps, some have governors built into the pump and some use the governor much like the gas tractors. I think the one with it's own governor is a later pump but am not sure. The P pumps have the injector lines attached to the pump in a circle and the A pumps have the injector lines attached in a row.
David B
bruce
03-18-2004 17:52:57
The G1SF in front of the serial# stand's for gas,regular altitude,standard with foot clutch.If you look under the u-frame it should have a date casted into it.If you could forward this to me it would help.Does the tractor hve a standard straight axle in it.
derf
03-18-2004 21:52:11
 Re: Re: serial # in reply to bruce, 03-18-2004 17:52:57
IN the cast is 1-13-53.seems odd to have the G . THANKS for the info DERF
