Tom
03-18-2004 16:11:56
Re: Massey 85 gas need help with part in reply to Randall, 03-18-2004 09:03:47
Randall, your first step should be to get 3 real MF brand manuals for this tractor. Get the Operator Manual, Repair Manual, and Parts Manual. They are available from your MF dealer. You need all three. Second step: Change ALL fluids: final drives, transmission, hydrolic, power steering, coolant. Change all filters. Use MF PermaTran III everywhere except the engine. Flush radiator. Use 50/50 mix plus cavitation additive. Change thermostat, engine belts. Inspect water pump. For the engine, use quality oil filter, and fill with a good 15W40 diesel engine oil, such as Mobil Delvac 1300, or Shell Rotella T. Third step: work the tractor some. Chnage the engine oil and filter again. Work the tractor some. You are now ready to assess what the tractor needs and by now you have found out most of the problems. Now how is the brakes, lift performance, steering, tires, leaks, draft control, and a host of other things. Good luck with your new tractor.
