165 fuel
G Cole
03-17-2004 19:55:40
A neighbor told me that adding about 1/2 quart of trans. oil to a tank of diesel fuel was good to clean the injectors ect. Is that true? Whats best to put in the system to clean it out? Thanks
Tom
03-18-2004 16:17:45
 Re: 165 fuel in reply to G Cole, 03-17-2004 19:55:40
Buy some Shella Rotella DFA (Diesel Fuel Additive), readily available at Walmart, TSC, or most anywhere. It is D### lot better than fooling around with ATF. DFA adds about 4 cetane numbers, prevents gelling, lubricates pump, lubricates injectors, cleans upper cylinders, removes moisture, prevents rust, and a host of other things. I use it in every gallon of diesel, year round. I have NEVER had a pump go out. One pump rebuild will buy a lifetime supply of DFA.
jake
03-18-2004 02:41:54
use atf, regular transmission oil isn't a good thing to add to the fuel...
G Cole
03-18-2004 07:09:31
 Re: Re: 165 fuel in reply to jake, 03-18-2004 02:41:54
Thanks for all the help. I meant ATF
sibby
03-18-2004 00:20:20
we used to add 1 pint to tankful of every new massey we pre delivered before they were delivered mainly to stop the fuel delivery valve in fuel inj. pump from sticking.
marlowe
03-17-2004 20:39:52
that has been done for years and years thats all i use in 9 diesal engines
